Rank: Guest
Groups: Guests
Joined: 8/10/2018(UTC) Posts: 0 Location: 99556 Was thanked: 4 time(s) in 4 post(s)
thanks for the simple fix!!!!
Rank: Guest
Groups: Guests
Thank you, it worked! I pushed the lever down and now have cubed ice!!
Rank: Guest
Groups: Guests
It fixed mine .thank you so much Mr,Noble
Rank: Guest
Groups: Guests
Omg, THANK YOU, I hate crushed ice, finally its working π€πππNote: My lever was stuck half way, so I did have to repeat the steps twice then it worked.
Rank: Guest
Groups: Guests
Rank: Guest
Groups: Guests
Originally Posted by: Guest 1. Take out the ice bin to access the switch in the freezer. 2. Underneath the ice bin is a metal rod. 3. In the back of the freezer there is a square hole from where the rod came. Put your finger in this hole. 4. You should feel a plastic lever. If it's up, push it down. If it's down, push it up. 5. Put the ice bin back and try for ice again. You should receive crushed and cubed ice at this time. 6. If you push the lever up or down and it doesn't stay in place we may need to schedule service.
This worked like a charm
Rank: Guest
Groups: Guests
Worked for me as well. In addition, I had to fish out two small pieces of ice that were blocking the switch.
Rank: Guest
Groups: Guests
Rank: Guest
Groups: Guests
What if you find the square hole but there's nothing in it? That's where I am right now. Stuck on crushed, and no lever or anything in the square hole.
