jakL357
#1 Posted : Friday, August 28, 2009 12:46:27 PM(UTC)
jakL357
I have a Kenmore fridge about 2.5 years old in age, model # 106.58529700. The ice dispencer door flap on the front door panel does not close properly. I do not know how to dismantle the door or even if I need to in order to view the inside of the dispencer. I assume a hinge or a spring of some sort has become broken or loose. When I manually hold the door flap closed with my hand it somehow resets the switch and when I press down to dispence ice, it works with no problem.
Does anyone have any ideas or has anyone had this same issue?
candleroma
#2 Posted : Wednesday, May 25, 2011 7:02:12 AM(UTC)
candleroma
Anyone else had this problem or get it fixed. The fridge is only 3 years old. It is a Kenmore.
