2 Pages12>
H. B. TEMPLE
#1 Posted : 15 years ago
H. B. TEMPLE
Ice Dispencer Locked On "crushed". Water Dispencer Ok.
#2 Posted : 15 years ago
Remove the ice container and the motor cover. Check the solenoid (#378 on the diagram) for continuity.
- The solenoid assembly Part number: AP2071947
If the solenoid is good, check for 120 VAC to the solenoid by pushing the ice release lever with the door switch taped in and the ice cubes selected. Post the results.
Here are the breakdown diagrams and Replacement parts for General Electric DSS25KGRDWW Refrigerator | AppliancePartsPros.com
jwgoodman
#3 Posted : 15 years ago
jwgoodman
Could this be the same issue with frigidaire..I am experiencing the same issue?
#4 Posted : 15 years ago
Yes, it could. What is the complete model number of the refrigerator?
jwgoodman
#5 Posted : 15 years ago
jwgoodman
Model: GLRS267ZDB2
Serial: LA44905688
#6 Posted : 15 years ago
Model: GLRS267ZDB2
Serial: LA44905688
You have to perform exactly the same troubleshooting.
The solenoid is shown as #45 on the diagram.
- The solenoid assembly Part number: AP3965560
EL Nobles
#7 Posted : 4 years ago
Guest
Rank: Guest
United States
1. Take out the ice bin to access the switch in the freezer.
2. Underneath the ice bin is a metal rod.
3. In the back of the freezer there is a square hole from where the rod came. Put your finger in this
hole.
4. You should feel a plastic lever. If it's up, push it down. If it's down, push it up.
5. Put the ice bin back and try for ice again. You should receive crushed and cubed ice at this time.
6. If you push the lever up or down and it doesn't stay in place we may need to schedule service.
thanks 1 user thanked Guest for this useful post.
Mastoo on 9/10/2021(UTC)
Guest
#8 Posted : 4 years ago
Guest
Rank: Guest
United States
It works!!! Thank you so much!!
Guest
#9 Posted : 4 years ago
Guest
Rank: Guest
United States
Wow, it fixed mine too. Where can we send your service fee?
Guest
#10 Posted : 3 years ago
Guest
Rank: Guest
United States
hole.
Solid advice!!! It worked. Much appreciated.
KITCHENAID ICE DISPENCER STUCK (Refrigerator & Freezer Repair)
by Guest 4 years ago
Ice Dispencer stops dispencing (Refrigerator & Freezer Repair)
by jmclanton 13 years ago
ice dispencer (Refrigerator & Freezer Repair)
by eduardoalmoite 13 years ago
Water/Ice Dispencer not working (Refrigerator & Freezer Repair)
by Jeff G. 13 years ago
Ice dispencer not working (Refrigerator & Freezer Repair)
by richmoralesinlincoln 13 years ago
Ice Dispencer Switch (Refrigerator & Freezer Repair)
by H. B. TEMPLE 15 years ago
Ice dispencer not crushing ice (Refrigerator & Freezer Repair)
by michaelrx 15 years ago
Ice Dispencer Door Flap Does Not Close (Refrigerator & Freezer Repair)
by jakL357 16 years ago
Ice Dispencer Door (Refrigerator & Freezer Repair)
by MALIK1 16 years ago
by steve250f 16 years ago
ICe dispencer will not rotate (Refrigerator & Freezer Repair)
by m218perez 16 years ago
GE Ice dispencer working intermittently. (Refrigerator & Freezer Repair)
by Bill D 17 years ago
2 Pages12>
