Don Fowler
#1 Posted : Monday, March 26, 2012 7:33:13 AM(UTC)
Don Fowler
Washer tub shakes and washer turns off during spin. With no clothes in tub it operates normally. The tub leans to rear of machine when it is not running. I had the age wrong on previous post.
Simon / APP Team
#2 Posted : Monday, March 26, 2012 12:50:31 PM(UTC)
Simon / APP Team
Groups: APP Team
Hello.
Most likely the problem is bad shocks (springs) or the support to which springs are attached.
Post the results and we will provide you with feather assistance.
Thank you.
Don Fowler
#3 Posted : Tuesday, March 27, 2012 8:15:23 AM(UTC)
Don Fowler
There is a post on bottom of tub assembly which looks like it should rest in a hole in a bracket. With it out of the hole the tub is not centered. When I get the tub centered it jumps out of the hole in the bracket.
Simon / APP Team
#4 Posted : Tuesday, March 27, 2012 9:32:54 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
The support is broken, it looks like tripod with three shocks/springs attached to it.
In you case the best thing will be replacing all this parts.
The support Part number: AP2906500
The springs Part number: AP4358664
Here are the breakdown diagrams and Replacement parts for Whirlpool LT5000XVW0 LAUNDRY CENTER | AppliancePartsPros.com
It,s a big job and require a spinner ranch to take the basket out. Let me now if you need any help.
Good luck. Thank you.
Guest
#5 Posted : Sunday, October 31, 2021 10:45:34 PM(UTC)
Guest
Rank: Guest
Groups:
United States
How do you know it’s the springs. Everything under my washer looks perfectly fine but it still spins unbalanced
Whirlpool Thin Twin out of balance (Washer Repair)
by Don Fowler 3/24/2012 12:26:16 PM(UTC)
