Joined: 10/30/2021(UTC) Posts: 0  Location: Louisiana
In process of replacing bake element for a Frigidaire model FGEW3065PDF. I’ m not sure what position the 2 wires should be connected. Both wires have white insulation, can’t see what color of wires. Dies it make a difference, left or right?
Groups: Expert
It should be ok either way. Just make sure the connectors fit snugly on the terminals. Loose connections create resistance, resistance gets hot and burns up the connection.
