pfoxharp
#1 Posted : Friday, December 29, 2017 7:15:54 AM(UTC)
pfoxharp
Our dishwasher has never done a stellar job on the dishes, and I've always thought the water level seemed low. We have slightly low water pressure, so maybe that's the problem.
But while I was thinking about this (yet again -- the machine is over 20 years old) it occurred to me that I don't know the answer to a basic question.
There are two mechanisms in the dishwasher to limit the water fill level. One is a timer, and one is a float switch. On our machine, the water always shuts off via the timer. Is this correct operation? Or, should it normally shut off due to the switch. If the latter, then our machine is really not getting enough water.
I guess the basic question is: which of those two mechanisms is the fallback, and which is the primary?
Thanks,
paul
ThatGuy
#2 Posted : Friday, December 29, 2017 3:39:41 PM(UTC)
ThatGuy
Groups: Expert
United States
The float switch is for safety. Its to keep the water from overflowing.
If you are not getting enough water, its either water pressure or a plugged up water inlet screen.
pfoxharp
#3 Posted : Sunday, December 31, 2017 8:22:46 AM(UTC)
pfoxharp
thanks -- i figured that the float was probably the safety, but once i started wondering, i needed to know for sure.
Water level control (Washer Repair)
by FLDAVE 12/8/2013 12:43:39 PM(UTC)
water level control kaput? Kenmore portable washer (Washer Repair)
by damenefee 10/25/2011 10:18:54 AM(UTC)
Installing Whirlpool water level control (Washer Repair)
by nnieser 3/27/2011 6:28:56 AM(UTC)
Water Level Control (Washer Repair)
by Hunter30 9/14/2010 11:16:12 AM(UTC)
timer control or water level control? (Washer Repair)
by Elehairyjob5 2/18/2010 6:13:30 AM(UTC)
which part do I need for water level control so washer does not over fill? (Washer Repair)
by Paul Bailey 8/13/2009 2:10:21 PM(UTC)
by johnnybnice 5/13/2009 7:16:01 PM(UTC)
Water Level Control does not work (Washer Repair)
by darkhorse 8/30/2008 4:21:25 PM(UTC)
