Dryer quits running afetr about 10min. seems to be very hot. checked lent screen and vent and have good flow while running. After about 20min am able to re-start again but will quit after another 10min.
THIS FORUM IS DEAD!!!!!!! |
I have to wait 15-20min befoe it will start agian. The drum turns, but not sure if it is easy or not!
That does sound like a motor overheating.
Perhaps try rotating the drum on a couple other units to get a feel for how much resistance the drum should have.
Open it up and check that the drum glides etc are OK. Check that the motor is not heavily clogged up with lint.
Note: this usually ends up needing a new motor. |
