AppliancePartsPros.com
Appliance Repair Help
Dryer Repair
dryer quits running but keeps counting down the time
dryer quits running keeps counting down the time. if you turn it off then back on does the same thing it beeps like it going to start, but doesn't it just counts down the time left on the cycle.
Originally Posted by: Gene  Hello Gene, the "Tech Sheet" link is dead. It goes nowhere. where can I find the tech sheet for a Senseon dryer (GEW9868KL0). I have the same problem with my dryer. It will not run, but the timmer will count down and beep like it just finished drying. Also when you hit start, it clicks like it's going to start, but does nothing but count down.
Originally Posted by: KentheCookieman  Hello Gene, the "Tech Sheet" link is dead. It goes nowhere. where can I find the tech sheet for a Senseon dryer (GEW9868KL0). I have the same problem with my dryer. It will not run, but the timmer will count down and beep like it just finished drying. Also when you hit start, it clicks like it's going to start, but does nothing but count down. Remove the front bottom access panel and check the belt. Replace the belt if it's broken. - The belt Part number: AP2911808
Dryer Repair
