John W Spencer
#1 Posted : Monday, May 25, 2009 3:02:06 PM(UTC)
John W Spencer
Dryer quits running afetr about 10min. seems to be very hot. checked lent screen and vent and have good flow while running. After about 20min am able to re-start again but will quit after another 10min.
#2 Posted : Monday, May 25, 2009 5:14:49 PM(UTC)
Replacement parts for GE DPSR483EA1WW | AppliancePartsPros.com
Sounds like your motor may be overheating and tripping it's internal thermal cutout.
Can you restart it as soon as it shuts off?
OR
Do you have to wait a few minutes?
Try rotating the drum by hand, it should rotate fairly easily.
John W Spencer
#3 Posted : Tuesday, May 26, 2009 1:32:40 PM(UTC)
John W Spencer
I have to wait 15-20min befoe it will start agian.
The drum turns, but not sure if it is easy or not!
#4 Posted : Wednesday, May 27, 2009 3:53:01 AM(UTC)
That does sound like a motor overheating.
Perhaps try rotating the drum on a couple other units to get a feel for how much resistance the drum should have.
Open it up and check that the drum glides etc are OK.
Check that the motor is not heavily clogged up with lint.
Note: this usually ends up needing a new motor.
Dryer Quits (Dryer Repair)
by usmc2033 3/6/2017 12:12:38 PM(UTC)
Dryer Quits After 1 minute (Dryer Repair)
by candyman43 1/22/2015 10:51:44 AM(UTC)
Dryer quits running when it warms up (Dryer Repair)
by Hobieone 10/30/2013 6:04:34 AM(UTC)
dryer quits turning (Dryer Repair)
by broearl 12/6/2011 11:21:06 AM(UTC)
Maytag dryer quits heating after 10 minutes of runtime and then it will restart (Dryer Repair)
by templin 5/11/2010 5:46:23 PM(UTC)
dryer quits running but keeps counting down the time (Dryer Repair)
by donnie546 4/5/2010 8:55:08 AM(UTC)
Maytag Dryer quits tumbling after a few minutes (Dryer Repair)
by CinderMom 7/27/2009 11:05:56 AM(UTC)
Dryer Quits Heating (Dryer Repair)
by Thomas41 4/27/2009 6:57:51 AM(UTC)
dryer quits running after a short time (Dryer Repair)
by magictickler 9/30/2007 5:19:41 PM(UTC)
