jgabbard
#1 Posted : 17 years ago
jgabbard
The primary winding on the H.V. Transformer is not showing any continuity when checked with voltmeter, Is this suppose to be like that and would that keep the microwave from heating?
kawfeeman
#2 Posted : 17 years ago
kawfeeman
if you checked continuity through the primary winding, did you also check each leg of the primary winding to ground ? did you check the fuse also for continuity ?
Amana microwave will not heat (Microwave Repair)
by ckiley 12 years ago
Microwave will not heat (Microwave Repair)
by scottdugan 13 years ago
by villano 13 years ago
by macguy44 13 years ago
by vknipp 14 years ago
by Cleatus 14 years ago
Microwave will not heat anything (Microwave Repair)
by Stevew1987 15 years ago
over the range Microwave will not heat (Microwave Repair)
by pdeclerck 15 years ago
PLEASE HELP! Microwave will not heat (Microwave Repair)
by tratra 15 years ago
Microwave Will not heat (Microwave Repair)
by Walt Lamb 16 years ago
by Lou C 16 years ago
by jrt1000 16 years ago
Microwave Will Not Heat (Microwave Repair)
by ocstanley 16 years ago
Microwave will not heat (all else is functional) (Microwave Repair)
by FLAD 16 years ago
Microwave will not heat (all else is functional) (Washer Repair)
