jgabbard
#1 Posted : Tuesday, December 18, 2007 4:10:12 PM(UTC)
jgabbard
The primary winding on the H.V. Transformer is not showing any continuity when checked with voltmeter, Is this suppose to be like that and would that keep the microwave from heating?
kawfeeman
#2 Posted : Wednesday, December 19, 2007 4:44:16 AM(UTC)
kawfeeman
if you checked continuity through the primary winding, did you also check each leg of the primary winding to ground ? did you check the fuse also for continuity ?
Amana microwave will not heat (Microwave Repair)
by ckiley 2/1/2013 11:51:23 AM(UTC)
Microwave will not heat (Microwave Repair)
by scottdugan 7/26/2012 7:29:30 AM(UTC)
by villano 1/18/2012 12:24:46 PM(UTC)
by macguy44 12/31/2011 7:10:24 PM(UTC)
by vknipp 1/29/2011 9:42:28 AM(UTC)
by Cleatus 12/20/2010 4:40:14 PM(UTC)
Microwave will not heat anything (Microwave Repair)
by Stevew1987 1/2/2010 6:44:11 AM(UTC)
over the range Microwave will not heat (Microwave Repair)
by pdeclerck 12/27/2009 4:07:14 PM(UTC)
PLEASE HELP! Microwave will not heat (Microwave Repair)
by tratra 12/2/2009 8:28:30 PM(UTC)
Microwave Will not heat (Microwave Repair)
by Walt Lamb 4/2/2009 10:29:06 AM(UTC)
by Lou C 3/25/2009 1:57:18 PM(UTC)
by jrt1000 1/27/2009 7:34:52 PM(UTC)
Microwave Will Not Heat (Microwave Repair)
by ocstanley 12/28/2008 7:19:44 AM(UTC)
Microwave will not heat (all else is functional) (Microwave Repair)
by FLAD 12/15/2008 11:57:20 AM(UTC)
Microwave will not heat (all else is functional) (Washer Repair)
by FLAD 12/15/2008 10:38:17 AM(UTC)
