FLAD
#1 Posted : 16 years ago
FLAD
All functions of the microwave seem to work
- Lights
- table rotation
- fan
- timer
- clock
I opened the unit and found the schematic diagram. Went thru some of the basic checks. When running the unit with a large cup of I noticed a burning smell. Upon further inspection I noticed that the low voltage transformer P/N DE26-20155B SLV - 1350U (P) appears to have burn marks on two sides. (place where the channels are if I am describing it correctly).
Q1: Would this explain the full functionality minus the in-ability to heat items?
Q2: Is the part replacable or do I have to replace the entire "Smart board"? Cost is $173 versus approx. $20.0 to just replace the LVT1.
Q3: If the transformer is replacable. Is it hard to do?
Finally, given the symtoms are there any other parts which could be damaged?
#2 Posted : 16 years ago
This is a duplicated thread.
Answered here: http://forum.appliancepartspros...all-else-functional.html
Microwave will not heat (all else is functional) (Washer Repair)
by FLAD 16 years ago
