The washer fills normally, but doesn't agitate, sort of clunks like stripped gear. Spins ok and empties water but with a howl. Guides seen confusing, one says it might be motor assembly but others say transmission? Big difference in time and difficulty of repair. Any help appreciated.
Joined: 6/13/2014(UTC) Posts: 781   Was thanked: 1 time(s) in 1 post(s)
Sounds more like the tranny as the motor you say works in spin mode.
