Roberthill
#1 Posted : Thursday, August 24, 2017 6:07:23 AM(UTC)
Roberthill
When dryer stops it won't restart until it cools down ,which takes about a hour or more . When it stops and you press start button it sounds like it's going to start but the noise stops and when you press start button you get nothing.
thorning
#2 Posted : Friday, August 25, 2017 5:35:34 AM(UTC)
thorning
This sounds like a motor with worn bearings. It will probably require a new motor as the bearings cannot be replaced or cleaned/lubed. The thermal cutout of the motor is doing its job.
Dryer Won't Restart After A Load Or 2 (Dryer Repair)
by TBALLIN187 7/20/2009 4:46:28 PM(UTC)
Dryer won't restart (Dryer Repair)
by gmoney0287 11/28/2008 9:09:02 AM(UTC)
Dryer won't restart after it is warm (Dryer Repair)
by doverdave@juno.com 5/30/2008 10:26:58 AM(UTC)
