pepsiman62
#1 Posted : Sunday, May 24, 2009 8:19:32 AM(UTC)
pepsiman62
heres the model # fed300es thank you
#2 Posted : Sunday, May 24, 2009 9:53:29 AM(UTC)
PROBLEM:
broil and bake light stays on oven will not heat up.can u tell me the problem?
Replacement parts for FRG FED300ESB | AppliancePartsPros.com
Here is a wiring diagram
http://manuals.frigidaire.com/p...assomption/318271902.pdf
And some timer info
http://manuals.frigidaire.com/p...assomption/318200144.pdf
Use POST REPLY at the bottom so that your response becomes part of this thread.
Odds are high that the control board is shot.
Open it up and check the wires from the elements to the control board.
Remember to unplug the unit, 240 volts is lethal.
I would also check the temperature sensor. Note this should give an error but it may be a possibility. See this link, check out # 7 and 8:
http://www.applianceaid.com/elecrange.html
1960's Oven Repair - Need model # (Oven Repair (including Ranges and Cooktops))
by jarla 12/13/2020 10:48:51 AM(UTC)
GE oven repair (Oven Repair (including Ranges and Cooktops))
by arshlo 12/10/2016 7:51:10 AM(UTC)
Oven Repair (Oven Repair (including Ranges and Cooktops))
by ridenroaddog 12/9/2013 11:06:59 AM(UTC)
by ANTHONYMAYWEATHERS 8/5/2013 4:45:40 PM(UTC)
by miguel 2 4/14/2013 10:06:22 AM(UTC)
Frigidaire Oven Repair Problem (Oven Repair (including Ranges and Cooktops))
by PetraMarion 2/25/2013 4:58:33 AM(UTC)
by johnthrasher45 2/9/2013 12:04:31 PM(UTC)
by johnthrasher45 2/8/2013 10:04:38 AM(UTC)
Oven repair (Oven Repair (including Ranges and Cooktops))
by johnthrasher45 2/8/2013 3:57:12 AM(UTC)
by johnthrasher45 2/7/2013 11:59:12 AM(UTC)
Questioning my first Oven Repair (Oven Repair (including Ranges and Cooktops))
by morbe 1/4/2013 1:18:05 PM(UTC)
by artalba 12/16/2012 5:07:10 PM(UTC)
GE Oven Repair Question? (Oven Repair (including Ranges and Cooktops))
by ejprap 11/7/2012 4:30:59 AM(UTC)
by gettone 10/23/2012 6:08:08 AM(UTC)
amana oven repair (Oven Repair (including Ranges and Cooktops))
by woodrow 10/16/2012 2:18:10 PM(UTC)
