mr2turbo
#1 Posted : Thursday, June 29, 2017 10:03:41 AM(UTC)
mr2turbo
Temp on the freezer won't go lower than 0 degrees. Refrige side doesn't go below 39 . it will fluctuate and not stay accurate.
#2 Posted : Thursday, June 29, 2017 3:43:00 PM(UTC)
What is the make of the refrigerator?
Why do you need the temperature in the freezer bellow 0°F?
Both temperatures you posted are pretty normal, in accordance with FDA regulations.
mr2turbo
#3 Posted : Friday, June 30, 2017 2:56:59 AM(UTC)
mr2turbo
I have a viking dsfb548d. The freezer goes up to 10 degrees and refrigerate 47 when I check occassionally.
#4 Posted : Friday, June 30, 2017 7:52:13 PM(UTC)
Very likely the condenser coil needs cleaning. Such refrigerators are very sensitive to the condition of the condenser coils. If you could not locate them, you may want to hire a pro.
