AppliancePartsPros.com
Appliance Repair Help
Refrigerator & Freezer Repair
Freeser and refridge goesup 5 degree of what it is set a couple of time a day.
Temp on the freezer won't go lower than 0 degrees. Refrige side doesn't go below 39 . it will fluctuate and not stay accurate.
What is the make of the refrigerator?
Why do you need the temperature in the freezer bellow 0°F?
Both temperatures you posted are pretty normal, in accordance with FDA regulations.
I have a viking dsfb548d. The freezer goes up to 10 degrees and refrigerate 47 when I check occassionally.
Very likely the condenser coil needs cleaning. Such refrigerators are very sensitive to the condition of the condenser coils. If you could not locate them, you may want to hire a pro.
