dkellogg
#1 Posted : Tuesday, October 28, 2008 9:24:39 AM(UTC)
dkellogg
The gasket on my freezer door won't seal at the bottom. The door looks to be mounted properly. This problem started a few months ago. I have ordered the replacement freezer door gaske but can't see how to get the old gasket off and the new on. Is this ust a bayonet fit? I see no screws anywhere to loosen. The exploded drawing isn't clear enough. I can just yank the old off but don't want to unless I have a reasonable hance to get the new one on!
v2k04
#2 Posted : Tuesday, October 28, 2008 11:22:17 AM(UTC)
v2k04
Most of the new friges have a channel in the door and the gaskets just snap in them the old school ones had a zillion screws going around the gasket
lorenglennen
#3 Posted : Saturday, May 23, 2009 8:02:31 AM(UTC)
lorenglennen
We have the old one with the screws, but i am not sure if we need a new gasket or if it is not sealing due to some other problem.
woodchuckie
#4 Posted : Saturday, May 23, 2009 8:30:03 AM(UTC)
woodchuckie
You have a door closing cam which could cause your problem. The cam raises the door 1/4 inch when it's opened and this helps close the door. If it's broken the gasket can be distorted or damaged. Inspect the action of the door to determine if this is your problem.
Part 14 on diagram 5 Replacement parts for WHIRLPOOL KSRB27FHSS02 | AppliancePartsPros.com
This is the freezer door as the fridge door did not have a diagram.
upright freezer frosting/icing after gasket replacement (Refrigerator & Freezer Repair)
by woakley 9/30/2019 7:09:57 AM(UTC)
LG fridge door gasket replacement - french doors (Refrigerator & Freezer Repair)
by bcarroll7 7/28/2019 11:14:38 AM(UTC)
Gasket replacement for Imperial freezer (Refrigerator & Freezer Repair)
by bdcane 9/3/2017 8:38:37 AM(UTC)
Door Gasket replacement (Refrigerator & Freezer Repair)
by mlbmark 12/6/2012 4:38:53 PM(UTC)
Front Loader gasket replacement (Washer Repair)
by maduro858 12/11/2011 7:22:43 PM(UTC)
Refrigerator door gasket replacement (Refrigerator & Freezer Repair)
by Tom Carty 6/23/2011 9:22:00 AM(UTC)
Fridgerator door gasket replacement (Refrigerator & Freezer Repair)
by plumber365 1/25/2011 5:50:02 PM(UTC)
Front Rubber Gasket replacement (Washer Repair)
by cbonasera 9/26/2010 11:43:22 AM(UTC)
Whirlpool Oven Gasket Replacement (Oven Repair (including Ranges and Cooktops))
by dwell 8/18/2010 8:03:46 AM(UTC)
Bottom freezer door gasket replacement (Refrigerator & Freezer Repair)
by PageinSC 7/18/2010 7:42:53 AM(UTC)
by grenoble 4/9/2010 7:23:57 AM(UTC)
HE3T Door gasket replacement (Washer Repair)
by gbramhall 1/13/2010 3:41:41 PM(UTC)
ap4010226 gasket replacement (Washer Repair)
by RINKYDINKS 1/2/2010 4:38:27 PM(UTC)
Tub Gasket Replacement Help (Washer Repair)
by jrussell_75423 12/22/2009 9:37:42 AM(UTC)
freezer gasket replacement (Refrigerator & Freezer Repair)
by cleaver 12/15/2009 12:27:21 PM(UTC)
