stevencurtiss
#1 Posted : Saturday, February 25, 2017 7:19:56 AM(UTC)
stevencurtiss
My washer goes through all cycles but stops at the rince cycle whats wrong with it i think maybe water valve? ??
ThatGuy
#2 Posted : Saturday, February 25, 2017 9:25:28 AM(UTC)
ThatGuy
Groups: Expert
United States
Your description is a little vague.
So are you saying the washer fills with water OK, then agitates OK, but fails to drain and spin in the rinse part of the cycle? Or are you saying something else?
Is it filling with rinse water? Is it draining and is it spinning? Do you have both cold and hot water? Have you checked your lid switch? Does it click when you shut the lid?
stevencurtiss
#3 Posted : Saturday, February 25, 2017 9:32:18 AM(UTC)
stevencurtiss
it does not rinse at all but spin an drain cycle works
ThatGuy
#4 Posted : Saturday, February 25, 2017 11:44:59 AM(UTC)
ThatGuy
Groups: Expert
United States
Is it filling with rinse water? Do you have both cold and hot water?
stevencurtiss
#5 Posted : Saturday, February 25, 2017 1:02:11 PM(UTC)
stevencurtiss
Yes both hot an cold no its not filling up to rinse i tried switching the silanoids around but that just made the water constantly run so I think im going to need a timer lid works an clicks good i also noticed the cold water valve is stuck open
