RowdyRedRaider
#1 Posted : Sunday, February 19, 2017 5:45:52 PM(UTC)
RowdyRedRaider
I have a Kitchenaid Superba that isnt making ice. I replaced the ice maker about 2 years ago. I just put a jumper wire in T and H holes and it filled raised the plastic teeth and then filled with water. Looks like it is starting to ice up. The arm will not raise it just hangs down. What might the issue be?
Rowdy Red
RowdyRedRaider
#2 Posted : Monday, February 20, 2017 6:57:54 AM(UTC)
RowdyRedRaider
Turns out the ice maker is 5 years old. So it made at least 2 to 3 batches of ice and stopped again. Looks like the fingers that push the ice out are in the up position and have ice on them. I have attached a picture of them.
Marc
RowdyRedRaider attached the following image(s):
Kitchenaid KSRG25FKSS15 Refridg buzz/rattle on compressor start (Refrigerator & Freezer Repair)
by Guest 6/23/2024 8:35:15 AM(UTC)
Kitchenaid refrigerator and freezer intermittently to warm (Refrigerator & Freezer Repair)
by Guest 6/18/2024 12:12:20 PM(UTC)
Kitchenaid KDTE254ESS1 Heater Element (Dishwasher Repair)
by charlie9876 5/28/2024 8:18:41 AM(UTC)
KitchenAid KSC25INSS01 (Refrigerator & Freezer Repair)
Belarus KKellyNC 5/23/2024 4:25:25 AM(UTC)
Kitchenaid Oven range Superba kgsc308lss0 not heating up (Oven Repair (including Ranges and Cooktops))
by rattty 5/19/2024 6:51:16 PM(UTC)
Kitchenaid KDTM604KPS0 (Dishwasher Repair)
by Guest 5/12/2024 5:24:44 AM(UTC)
KitchenAid freezer gasket needed (Refrigerator & Freezer Repair)
by Kris Ballew 4/30/2024 6:27:57 PM(UTC)
KitchenAid freezer door stuck (Refrigerator & Freezer Repair)
by willeaton 4/18/2024 7:31:34 AM(UTC)
KitchenAid KSC25INSS01 issues (Refrigerator & Freezer Repair)
by KKellyNC 4/16/2024 7:28:06 PM(UTC)
Kitchenaid KSSC48QMS02 (Refrigerator & Freezer Repair)
by VinRenzi 4/2/2024 6:26:11 AM(UTC)
Kitchenaid Refrigerator Ice chute frosting up and clogging (Refrigerator & Freezer Repair)
by Guest 3/26/2024 9:05:12 AM(UTC)
Built-In Kitchenaid Mdel KSSC42QMS00 Refrigerator (Refrigerator & Freezer Repair)
by Guest 3/25/2024 6:29:18 AM(UTC)
KitchenAid KSSP42QTS00 Ice dispenser leaking (Refrigerator & Freezer Repair)
by sternern 3/20/2024 2:21:47 PM(UTC)
Kitchenaid ktdm354dss3 doesn’t close completely at the top (Dishwasher Repair)
by Guest 2/29/2024 12:36:40 PM(UTC)
KitchenAid Gar Range - Oven Intermittent Lighting (Oven Repair (including Ranges and Cooktops))
by JDinKTX 2/25/2024 5:05:21 AM(UTC)
