MCW750
#1 Posted : Wednesday, October 12, 2016 7:25:49 AM(UTC)
MCW750
compressor is not running; getting ready to check connection from muthaboard to inverter for voltage. Should the voltage at the (J15)connection be between 4-6 volts? Does the refrigerator need to be plugged in to check this.
cbmserviceguy
#2 Posted : Thursday, October 13, 2016 4:07:38 AM(UTC)
cbmserviceguy
Is the compressor fan or evaporator fan running? You can check voltage at the compressor leads or pull up the wiring diagram and check at the control board. Voltage checks do require the unit to be plugged in...
MCW750
#3 Posted : Thursday, October 13, 2016 6:25:17 AM(UTC)
MCW750
Fan is running
cbmserviceguy
#4 Posted : Thursday, October 13, 2016 10:36:15 AM(UTC)
cbmserviceguy
Does the inverter on the compressor smell burnt, have any deformities or discoloration? Its sounds like it's the culprit.
Guest (4)
Whirlpool Refrigerator Not Cooling - Intermittently (Refrigerator & Freezer Repair)
by ljsmith9999 2/3/2022 6:53:41 AM(UTC)
Whirlpool Refrigerator not cooling (Refrigerator & Freezer Repair)
by tokazawe 1/7/2014 6:56:17 PM(UTC)
Whirlpool Refrigerator Not Cooling But Freezer Works (Refrigerator & Freezer Repair)
by stefannsgirl 12/4/2013 5:28:45 PM(UTC)
Side by side whirlpool refrigerator not cooling! (Refrigerator & Freezer Repair)
by J1love 7/10/2013 6:09:58 AM(UTC)
Whirlpool refrigerator not cooling, compressor very warm (Refrigerator & Freezer Repair)
by brentcd 9/20/2012 7:46:19 AM(UTC)
whirlpool refrigerator not cooling (Refrigerator & Freezer Repair)
by dinoking 5/3/2011 8:17:55 PM(UTC)
Whirlpool Refrigerator not cooling.. Fan Problem? (Refrigerator & Freezer Repair)
by petesmo 8/31/2010 2:54:02 PM(UTC)
Whirlpool refrigerator not cooling (Refrigerator & Freezer Repair)
by rasterscreen 12/7/2008 7:57:00 PM(UTC)
