I have a Kenmore dishwasher 665.16372301. It just stopped working. You press the "normal" wash button and start - nothing happens. The "normal" button stays lite for a while, then goes off.
Did any light on the control panel blink? Did it make any noise?
light stayed on for a minute or so, then went dark. No blinking
Check the door switches and the wires. Check if there is 120VAC to the control board. Post the results.
We ordered a new control panel and it lasted less than a week. So something else must be causing it to go out
What is the part number of the control panel you replaced? What it does now?
I don't have the part number right now, I ordered it from sears. It doesn't turn on and none of the panel lights lite, and as a bonus, there is standing water in the bottom
