Stone JR
#1 Posted : Sunday, August 21, 2016 11:25:13 AM(UTC)
Stone JR
I am not getting no water to ice maker. I am getting water to water dispenser in door. Replaced ice maker module and dual inlet valve with no luck. Any help would be great
#2 Posted : Monday, August 22, 2016 3:53:12 PM(UTC)
There are a few things you may want to do.
1. Make sure the side arm is in On (down) position.
2. The freezer temperature should be above 3ºF.
3. Check the ice maker fill tube
4. Remove the ice maker head cover and using a voltmeter check for 120 VAC between the test points L and N. If the source voltage is not present, check all ice maker connections.
5. If the ice maker fails to initialize the harvest, a jumper wire (made from a short piece
of good insulated 14 gauge electrical wire that has been stripped back 1/2 inch on both ends) can be used to start the cycle. Inserting the jumper between contacts T and H will simulate
the closing of the thermostat and will energize the timer motor and the heater. Remove
the jumper after 3 seconds. The ice maker should continue to run without the
jumper in place.
If the icemaker starts when the jumper is inserted, the thermostat is defective. If this the case, the whole ice maker would need to be replaced.
The part number for the ice maker is Part number: AP6016628
You can order it from AppliancePartsPros.com for $68.03
P.S. It's always a good idea to replace the whole ice maker instead of repairing the old one. Much better rate of success and finally real saving of money.
margie02
#3 Posted : Monday, September 4, 2017 2:40:34 AM(UTC)
margie02
I have a kenmore side by side model #1069545510 I replaced the water inlet valve but still no water to icemaker, what could the problem be.
margie02
#4 Posted : Monday, September 4, 2017 2:51:26 AM(UTC)
margie02
I have a kenmore side by side model # 1069545510 there is no water going to icemaker. I replace inlet valve but still no water to ice maker, water goes to water dispenser fine. What do I need to check now?
Samsung side by side refrigerator No water to ice maker (Refrigerator & Freezer Repair)
by mtrafton 5/29/2020 5:25:03 AM(UTC)
No water to ice maker / water works through door (Refrigerator & Freezer Repair)
by mservice 3/15/2019 4:16:54 PM(UTC)
No water to ice maker or door (Refrigerator & Freezer Repair)
by scar1 1/12/2019 12:49:56 PM(UTC)
No Water To Ice Maker (Refrigerator & Freezer Repair)
by Daussie 6/16/2017 6:42:49 AM(UTC)
No water dispenses, no water to ice maker (Refrigerator & Freezer Repair)
by jeffreyjd@charter.net 2/5/2013 5:17:45 PM(UTC)
by sydnoid 10/22/2012 6:20:09 PM(UTC)
No Water To ice Maker (Refrigerator & Freezer Repair)
by phuluu 6/7/2012 9:34:28 PM(UTC)
by s_pierce 5/29/2012 9:25:09 AM(UTC)
by barbaraann 3/26/2012 11:36:20 AM(UTC)
No water to Ice Maker or Door Unit (Refrigerator & Freezer Repair)
by Kevin933 11/30/2011 11:44:20 AM(UTC)
No Water to Ice Maker or Water Dispenser (Refrigerator & Freezer Repair)
by JoeSavo 8/8/2011 1:20:18 PM(UTC)
by tkirsch 6/21/2011 10:54:58 AM(UTC)
Frigidaire No water to ice maker (Refrigerator & Freezer Repair)
by taberd1985 6/12/2011 8:23:55 PM(UTC)
by pwg02001 4/22/2011 10:52:31 AM(UTC)
Kenmore no water to ice maker. (Refrigerator & Freezer Repair)
by JooeII 4/2/2011 10:12:49 AM(UTC)
