:confused: Washer would not high speed spin after replacing MCU. Replaced CCU and now will not start. F99 code only.
Joined: 6/13/2014(UTC) Posts: 781   Was thanked: 1 time(s) in 1 post(s)
F99 NOT SUPPORTED User selected on the UI the unsupported Cycle on the CCU. Mismatch of User Interface and CCU or corrupted EEPROM. Possible Causes/Procedure 1. Perform Service Cycle to pair the UI and CCU SW. 2. Replace User Interface. If failure still present: 3. Also replace the CCU.
[MODEL][/MODEL] What is "Service Cycle"? I tried the diagnostic process and only got flashing lights along with "F99" flashing on the display. Is there a way to tell whether the problem is in the CCU or in the UI?
I wish the manual to this washer was written as well as the one you reference. The controls are very different on that machine though.
I will keep searching for the service manual for this machine. Hopefully someone else on this forum might be able to pitch in!
I have the service manual which came with the machine. The problem is that it does not have enough info to get me there. I am changing the CCU back to the old one for now to confirm that the machine returns to its previous state.
After reinstalling the old CCU board I now have an F71 fault. This seems to point to the UI causing the F99 with the new CCU. Am I thinking correctly?
Thanks for the reply. I have replaced the MCU twice. The second time it made no difference in my low speed spin. I still have two MCU boards, one of which I have not used. I could easily change again but I am skeptical. I guess no harm done tho.
