WintonP
#1 Posted : Tuesday, July 5, 2016 4:48:32 PM(UTC)
WintonP
Dishwasher is leaking from underneath, in the front right corner. Photo attached -- water seems to be coming down from this white perforated plastic piece. Any tips?
WintonP attached the following image(s):
WintonP
#2 Posted : Wednesday, July 6, 2016 6:19:45 AM(UTC)
WintonP
The leak is coming from the port where the float switch is.
ProudDaddy
#3 Posted : Monday, November 7, 2016 10:14:46 AM(UTC)
ProudDaddy
WintonP, Did you resolve your leak? If so, how? I have a WDT790SAYB0 that appears to have the same problem. Not quite four years old now; been going on for over a year.
I have water dripping from the plastic cover. The leak is periodic. Sometimes twice in a week then it may go 8-9 months before it leaks again. I took the door apart and noticed the insulation in the lower portion of the door is damp. That and the fact that is leak is very intermittent, I thought that it might be electrical so I swapped the float switch out. But three weeks later, I've got another leak.
WintonP
#4 Posted : Monday, November 7, 2016 10:27:12 AM(UTC)
WintonP
Repair guy found nothing wrong and said it could have been the result of a dish or something poking down from the bottom rack and making the arm spin funny. Doesn't sound like a legit answer to me, but it hasn't leaked since.
ProudDaddy
#5 Posted : Monday, November 7, 2016 11:22:55 AM(UTC)
ProudDaddy
Thanks! I appreciate the reply. I hope that's true for yours.
About a year ago I contacted a repairman who told me something similar. He also suggested there could be something clogging or diverting spray from one of the nozzles in a direction its not supposed to be spraying. So I cleaned all the ports out, top and bottom. For mine, its the periodic part that's killing me.
I'm probably going to start throwing parts at it. I think there is a gasket/seal where the float passes through; I'll probably change that next. But, that doesn't answer why the door insulation is damp.
Good luck!
Whirlpool Leaking Oil and Clothes Still Damp (Washer Repair)
by jeffceo 1/29/2017 5:03:34 PM(UTC)
Whirlpool leaking from Inlet Valve (Dishwasher Repair)
by dbayducks 2/8/2015 11:58:28 AM(UTC)
Whirlpool Leaking need part have Picture (Dishwasher Repair)
by Blakester117 5/9/2013 12:25:45 PM(UTC)
Whirlpool leaking water into fridge (Refrigerator & Freezer Repair)
by Renlord 10/25/2010 5:36:23 AM(UTC)
whirlpool leaking (Dishwasher Repair)
by jmkitson 11/7/2009 12:45:17 PM(UTC)
whirlpool leaking from bottom (Refrigerator & Freezer Repair)
by krg8411 8/30/2008 8:44:51 AM(UTC)
Whirlpool leaking fluid on floor (Washer Repair)
by idobelieve 8/14/2008 11:19:36 AM(UTC)
