dmaruca
#1 Posted : Friday, July 1, 2016 5:36:55 AM(UTC)
dmaruca
Hello
I have a 6 year old dryer that gets lots of use. I need a technician that can help me with a very difficult problem. The initial problem was the wrong orfices in my gas valve, I have a propane dryer that had natural gas orfices and ultimately after putting in the right orfices and changes the high limit thermostat which was burned, the dryer worked fine. Now it works intermittently. It will do a few loads fine and than the next few will be wet. I've changed the gas valve and coils which did not work. I changed the main board which did not work. I've tested all the heating parts with an ohms meter and they seem to be giving proper readings. The glow igniter always comes on but the flame does not always comes out when cycling through. I am at my wits end but would like to try a few more parts before I give up!
Thanks...Dave
Maytag MEDC200XW1 - Intermittent heat and no buzzer (Dryer Repair)
by Lemarac 1/9/2019 4:09:17 PM(UTC)
electric dryer intermittent heat (Dryer Repair)
by wags1970 7/11/2017 9:31:33 AM(UTC)
gas dryer with intermittent heat (Dryer Repair)
by highpoint 1/21/2017 12:14:48 PM(UTC)
Intermittent Heating (Dryer Repair)
by lccent 8/7/2015 9:19:56 AM(UTC)
Intermittent heating. Now none. (Microwave Repair)
by bstruss 2/23/2015 6:29:10 PM(UTC)
Intermittent heating problem with gas dryer (Dryer Repair)
by David L. Mandel 8/16/2014 8:21:23 PM(UTC)
by colbey 7/11/2014 4:55:38 PM(UTC)
LG electric dryer Intermittent Heat (Dryer Repair)
by Saurin 10/2/2013 7:41:23 PM(UTC)
by greg.od11@gmail.com 8/21/2013 3:29:48 PM(UTC)
Gas Dryer Intermittent Heat (Dryer Repair)
by FranDaMan 7/4/2013 6:53:18 PM(UTC)
by gvel 5/19/2013 3:38:09 PM(UTC)
Gas Dryer - Intermittent heat, checked coils and igniter (Dryer Repair)
by nevets 11/18/2012 6:14:02 PM(UTC)
by rcady52 10/26/2012 12:03:54 PM(UTC)
Whirlpool Super Capacity 465 Oven...intermittent heating issue (Oven Repair (including Ranges and Cooktops))
by wetzelbp 9/3/2012 4:25:33 PM(UTC)
Maytag Dryer Intermittent Heat (Dryer Repair)
by jayjaysin 6/24/2012 4:59:26 PM(UTC)
