laufman89
#1 Posted : Thursday, April 18, 2013 6:37:00 PM(UTC)
laufman89
The dryer lights are displyed on the panel and door closes completely on the switch. When the Start button is pushed, I can hear a "click" sound but the dryer does not start. Ideas on what needs checked?
#2 Posted : Friday, April 19, 2013 1:42:29 AM(UTC)
Parts for Maytag MED6400TB0 Dryer - AppliancePartsPros.com
I am also assuming that the interior light works. This tells you that you have the voltage (L1 to Neutral, 120 volts) to run the motor.
First I would check that the belt is OK re: belt switch is closed
Next I would check the thermal fuse.
File Attachment(s):
MED6400.pdf (455kb) downloaded 33 time(s).
laufman89
#3 Posted : Saturday, April 20, 2013 4:51:42 PM(UTC)
laufman89
Denman, thanks for your reply and suggestions. It was the thermal fuse. Replaced it this evening and dryer is once again running.
Thanks again for your help.
Originally Posted by: denman Go to Quoted Post
gleeson
#4 Posted : Saturday, January 30, 2016 6:32:55 PM(UTC)
gleeson
I had the same thing on my dryer. I found on another forum that the relay was working on the circuit board but that the solder connection on the backside of the relay was blown out. I resoldered it and we are back in business.
Here is the link to the whole thread. My repair was on page 2 , but read page one first. :rolleyes:good luck
gleeson attached the following image(s):
Kenmore Elite dryer won't start (Dryer Repair)
by Guest 6/22/2024 6:34:42 AM(UTC)
LG DLEX5170V electric dryer won't start (Dryer Repair)
by Guest 2/23/2024 11:17:20 AM(UTC)
Dryer won't start after changing fuses and timer (Dryer Repair)
by Guest 1/17/2023 11:21:44 AM(UTC)
Dryer Won't start - Repair Video (Dryer Repair)
by Guest 8/8/2021 1:55:18 PM(UTC)
Kenmore 100 Series Dryer Won't Start (Dryer Repair)
by juser 11/7/2020 4:44:16 PM(UTC)
Gas dryer won't start at all (Dryer Repair)
by GuyGreg 2/21/2018 2:26:33 PM(UTC)
Dryer won't start (Dryer Repair)
by Ginadrc 1/26/2018 7:24:30 PM(UTC)
by Petem 12/2/2017 3:27:50 PM(UTC)
Maytag dryer won't start (Dryer Repair)
Belarus eagle243 11/15/2017 6:44:39 PM(UTC)
Dryer won't start after replacing the heating element (Dryer Repair)
by ivyholly 6/8/2017 6:45:42 PM(UTC)
Dryer Won't Start-Lights Blinking (Dryer Repair)
Belarus rleigh 6/5/2017 9:20:31 AM(UTC)
Inglis dryer won't start (Dryer Repair)
by jkeefe 4/20/2017 2:48:09 AM(UTC)
Amana Dryer won't start, but still gets hot (Dryer Repair)
by halfmoonranch 3/15/2017 9:38:33 AM(UTC)
Dryer won't start (mid-troubleshooting, could use some help) (Dryer Repair)
by OUberLord 3/13/2017 7:15:55 PM(UTC)
Whirlpool Dryer Won't Start (Dryer Repair)
by agjr200hp 2/5/2017 5:36:21 AM(UTC)
