bill weiss
#1 Posted : Monday, January 25, 2016 9:01:23 AM(UTC)
bill weiss
I replaced my bottom element on my upper oven, and it still only gets warm not hot. the upper element wrks fine
bill weiss
#2 Posted : Monday, January 25, 2016 12:59:45 PM(UTC)
bill weiss
Thank you for your help
The resistance on the old element was 28 ohms.
the upper element gets red.
the lower element stays at approximtely 150 degrees
there is no code indicated on the panel monitor
bill weiss
#3 Posted : Monday, January 25, 2016 12:59:49 PM(UTC)
bill weiss
bill weiss
#4 Posted : Monday, January 25, 2016 1:03:18 PM(UTC)
bill weiss
there is no code in the monitor screen
the upper element gets red, the lower stays at about 150 degrees.
the resistance of the old was 28 ohms.
THANK YOU VERY MUCH FOR YOUR HELP Bill
bill weiss
#5 Posted : Tuesday, January 26, 2016 11:55:45 AM(UTC)
bill weiss
I appologise for not getting back to you sooner, i have been out.
I put my hand on the lower element to feel the temp, and it never got hotter.
Is their any way i could measure the voltage at any given spot, to see if it is the relay or board. Thanks for your help Bill
bill weiss
#6 Posted : Tuesday, January 26, 2016 12:08:39 PM(UTC)
bill weiss
You have to excuse me i am illiterate when it comes to computers. i'm not sure i am sending the info right.My oven you push bake and set the temp you want, and when it reaches that temp it beaps Bill
bill weiss
#7 Posted : Wednesday, January 27, 2016 12:27:29 PM(UTC)
bill weiss
If the sensor was bad, would that not allow the lower element to get hot, but will let the upper to get hot, if the sensor is ok, does that mean the relay board is bad, or do they call that the control board. thanks very much for your help Bill
bill weiss
#8 Posted : Thursday, January 28, 2016 8:25:25 AM(UTC)
bill weiss
could the sensor be bad if the top element gets red hot and the bottom element only gets to about 120 degrees. thanks Bill
Guest (4)
