ginteal0
#1 Posted : Saturday, January 16, 2016 3:53:55 PM(UTC)
ginteal0
Began with not fully spinning/draining on final spin. Would respin/drain and seemed okay. After several loads like this the next load did not respin/drain when set to this and left water laying in washer. Tried next to start a cycle to watch exactly what was happening and it will now not even start a cycle. Lights come on, door lock light is on and door will not open but it will not even begin to fill.
ginteal0
#2 Posted : Sunday, January 17, 2016 2:57:30 AM(UTC)
ginteal0
Does this sound like it is the control board?
sidfink43
#3 Posted : Sunday, January 17, 2016 5:49:55 AM(UTC)
sidfink43
Not sure, the door lock assembly can also cause these symptoms.
Inside the lower service panel are tech notes that will tell you how to put it into diagnostic model and generate error codes and test some components. Focus on the door lock assembly and speed control board. But these models are hard to diagnose and in the end you may just have to start replacing parts and see what fixes it. If you buy the parts from this site you can return them if they are not needed.
ronaldschenk
#4 Posted : Monday, January 18, 2016 12:18:57 PM(UTC)
ronaldschenk
I also has a similar problem and the door switch assembly fixed the problem. There is more than one circuit the door switch is handling.
frigidaire wall oven 6564063 (Oven Repair (including Ranges and Cooktops))
by Guest 7/2/2024 12:40:53 PM(UTC)
Frigidaire dishwasher code A (Dishwasher Repair)
by Evandtam 6/27/2024 5:11:41 PM(UTC)
Frigidaire fill tube leak: Is it just a bad design? (Refrigerator & Freezer Repair)
by bobhucker 6/18/2024 7:59:46 AM(UTC)
Frigidaire oven won’t heat (Oven Repair (including Ranges and Cooktops))
by Jseeders 6/16/2024 10:23:51 AM(UTC)
Frigidaire FGHT2055VF - light switch? (Refrigerator & Freezer Repair)
by ranger58 6/13/2024 11:14:06 AM(UTC)
Frigidaire Gallery Refridgerator (Dishwasher Repair)
by Guest 6/10/2024 9:18:21 AM(UTC)
Frigidaire FFHB2740PS2 No Power (Refrigerator & Freezer Repair)
by mnjeepmale 6/3/2024 5:19:45 AM(UTC)
Frigidaire French door temperature (Refrigerator & Freezer Repair)
by Guest 5/28/2024 4:10:07 AM(UTC)
Frigidaire PLHS238ZCB1 Refigerator compressor issues. (Refrigerator & Freezer Repair)
by TonyMertz 5/18/2024 9:32:13 PM(UTC)
Frigidaire oven issue (Dishwasher Repair)
by Guest 5/8/2024 12:45:18 PM(UTC)
Frigidaire Gallery dripping through water dispenser (Refrigerator & Freezer Repair)
by cascodo 5/6/2024 9:26:01 PM(UTC)
Frigidaire FFHT1835VB1 Stuck in Defrost Mode (Refrigerator & Freezer Repair)
by dcuozzo 5/6/2024 9:55:29 AM(UTC)
Frigidaire Affinity front loader code (Washer Repair)
by Volusiacrazy 5/1/2024 3:26:17 AM(UTC)
Frigidaire max load top load washer (Washer Repair)
by Guest 4/29/2024 9:02:43 AM(UTC)
Frigidaire fgus2642lf2 auger not getting power (Refrigerator & Freezer Repair)
by knmens 4/15/2024 6:17:43 PM(UTC)
