jimt1891
#1 Posted : Monday, January 11, 2016 8:19:30 AM(UTC)
jimt1891
When I start dryer it glows (watching through 1x1 hole) and ignites. After appx 6 minutes flame goes out. In 3 more minutes ignites again. I did not check again until 20 minute mark, no flame. Watch for a few minutes and glowed a few times but did not ignite.
thorning
#2 Posted : Tuesday, January 12, 2016 6:34:39 AM(UTC)
thorning
You may have a problem with the gas valve coils. They do sometimes fail to operate properly after working for a while when they stop working due to heat.
jimt1891
#3 Posted : Wednesday, January 13, 2016 5:35:29 AM(UTC)
jimt1891
Would those be the 2 located by the burner? Do you know if there is a how to vidio?
Thanks for your reply!
Samsung DV328AGW Dryer heats for 10 seconds then shuts flame off (Dryer Repair)
by attim0de 6/13/2024 8:07:31 AM(UTC)
Kenmore 100 dryer Heating Element (Dryer Repair)
by postalservice21 3/27/2024 6:43:17 AM(UTC)
LG dryer heat stops during load (Dryer Repair)
by Guest 4/15/2023 10:14:22 AM(UTC)
LG Dryer Heater Thermistor Error (Dryer Repair)
by Guest 11/16/2022 8:37:57 AM(UTC)
Dryer heating in timed cycle but now heating in oher cycles (Dryer Repair)
by bblossm 2/19/2022 4:32:16 PM(UTC)
Dryer heating sometimes (Dryer Repair)
by Guest 2/13/2022 4:07:15 PM(UTC)
Kenmore Dryer Heat and Run issue (Dryer Repair)
by IDConundrum 10/26/2020 7:06:47 PM(UTC)
Whirlpool dryer heats for a bit then stops (WGD6400SW1) (Dryer Repair)
by don_caruana 9/2/2020 6:35:54 PM(UTC)
Samsung Electric dryer heating issue (Dryer Repair)
by £∆Z€R* 6/18/2020 10:08:23 AM(UTC)
Gas Dryer heat cycles on and off (Dryer Repair)
by Al Lynch 4/23/2020 10:47:08 AM(UTC)
Kemore elite dryer heating coil not heating (Dryer Repair)
by kenmodel 1/27/2020 7:50:40 PM(UTC)
Samsung Dryer heats then stops working and begins beeping. (Dryer Repair)
by jmm0816 6/1/2019 5:54:04 AM(UTC)
Dryer Heats, but drum does not turn (Dryer Repair)
by tzmango 2/21/2019 1:47:43 PM(UTC)
Dryer heats up but takes too long to dry (Dryer Repair)
by bear0729 11/13/2018 6:35:10 AM(UTC)
Electric Admiral Dryer heating problems. (Dryer Repair)
by ShaneBurle24 7/12/2018 8:32:23 AM(UTC)
