Grady White
#1 Posted : Sunday, January 10, 2016 10:30:53 AM(UTC)
Grady White
When trying to set the clock or timer, the digits bounce around. When trying to increase the time the numbers might go up then down then up. Nothing feels bad with the shaft but... Any suggestions would be appreciated.
#2 Posted : Sunday, January 10, 2016 10:39:58 AM(UTC)
Parts for Maytag CWE4020ACB Oven - AppliancePartsPros.com
Could be the potentiometer (pot) is bad. If that is what is used to set the time.
Get a can of electronics contact cleaner.
Unplug the unit.
Unplug the timer if you have to.
Then spray cleaner into the pot while rotating it back and forth.
Be sure to leave it long enough for the vapors to dissipate before reapplying power.
If that does nothing then you may have to live with it.
Note that there are companies out there that repair obsolete timers, Google "appliance timer repair".
Grady White
#3 Posted : Sunday, January 10, 2016 10:45:44 AM(UTC)
Grady White
Thanks for the quick reply. It doesn't feel like a pot. More like some kind of gear since you can feel 'clicks'. Any idea as to the function of part ID 23 on the control panel diagram is for? Here's a link to the parts page:
http://www.appliancepartspros.c...12p015-60-ap4108308.html
#4 Posted : Monday, January 11, 2016 3:04:14 AM(UTC)
Sorry but I do not know.
is clock/timer and oven control board the same (Oven Repair (including Ranges and Cooktops))
by blazerbrad 10/4/2012 1:27:29 PM(UTC)
Replaced clock/timer/EOC board, now oven won't heat at all help! (Oven Repair (including Ranges and Cooktops))
by cantbakebeth 1/28/2012 11:52:55 AM(UTC)
How to replace oven clock/timer? (Oven Repair (including Ranges and Cooktops))
by aec393 12/15/2011 11:46:50 AM(UTC)
Clock/Timer (Oven Repair (including Ranges and Cooktops))
by bena8837 8/16/2011 5:48:27 PM(UTC)
New Clock/Timer panel won't work (Oven Repair (including Ranges and Cooktops))
by rarellano81625 3/3/2011 1:10:27 PM(UTC)
Gene! New clock/timer board, light stays on (Oven Repair (including Ranges and Cooktops))
by wolfbbg 10/5/2010 3:30:36 PM(UTC)
Broken Whirlpool clock/timer on oven (Oven Repair (including Ranges and Cooktops))
by HRCJohn 12/30/2009 4:49:01 PM(UTC)
Help with clock/timer (Oven Repair (including Ranges and Cooktops))
by jacktrouble 10/9/2009 2:08:33 PM(UTC)
Clock/timer Display Meltdown While Self Cleaning Oven (Oven Repair (including Ranges and Cooktops))
by WANAGO 5/14/2009 7:40:23 AM(UTC)
Clock/timer (Oven Repair (including Ranges and Cooktops))
by olefin32 6/1/2008 1:44:31 PM(UTC)
clock/timer bizzare behavior, no fault code (Oven Repair (including Ranges and Cooktops))
by workpot 4/24/2008 1:38:48 PM(UTC)
Frigidaire Gas oven Clock/timer Replacement (Oven Repair (including Ranges and Cooktops))
by ChuckH 2/26/2008 11:19:09 AM(UTC)
no error codes; is Clock/Timer EOC the problem? (Oven Repair (including Ranges and Cooktops))
by 2132mg 2/9/2008 11:02:36 AM(UTC)
