steve80124
#1 Posted : Monday, September 21, 2015 2:15:04 PM(UTC)
steve80124
Hello:
I have a kitchenaid dishwasher that leaks on to the floor sporadically. When I open the front access panel along the floor, I saw a pretty steady drip (it's not the inlet valve on the left - that's dripping too and I already ordered one of those) from a white piece just in front of the main electrical connect panel. The white piece has 2 brown wires coming out of it. So I reached up to it and pressed it and I could hear a click as it was a toggle and the leaking stopped but the amount of water damage underneath and puddles I've observed in front tell me this is a recurring issue.
I've looked on the parts diagrams and can't figure out what this and what Part(s) I should order. I've attached a picture showing the part. Thanks!
steve80124 attached the following image(s):
#2 Posted : Wednesday, September 23, 2015 12:24:16 AM(UTC)
Parts for KitchenAid KUDS02FRSS3 Dishwasher - AppliancePartsPros.com
It is the overfill switch/mechanism (item 1 in section 06).
You will have to remove the float and check for cracks or crud or if the nut is tight.
Kitchenaid dishwasher leaking under door (Dishwasher Repair)
by chasethedream 1/1/2017 8:30:50 AM(UTC)
kitchenaid dishwasher leaking water from door (Dishwasher Repair)
by brasuca 1/20/2014 9:55:31 AM(UTC)
Kitchenaid dishwasher leaking from bottom (Dishwasher Repair)
by smithguy 5/22/2009 1:39:19 PM(UTC)
