martyglo
#1 Posted : Tuesday, May 19, 2009 10:24:35 AM(UTC)
martyglo
:confused: dryer starts when i turn the knob but stops when i release it. the burner doesn't come on. marty
#2 Posted : Tuesday, May 19, 2009 11:41:03 AM(UTC)
Replacement parts for GE DBSR453GA2WW | AppliancePartsPros.com
Sounds like the centrifugal mechanism in the motor is not working.
Cannot find a wiring diagram for this unit online. GE like to keep their techs busy so tech info is hard to come by.
On most dryers there are 2 switches that are part of the motor's centrifugal switch assembly. Thet are activated once the motor gets close to operating speed.
One closes and gives power to the heat. This ensures that heat cannot come on with the blower not working.
The other removes the start winding from the circuit and provides an alternate/parallel circuit path to the motor's main winding. Once the start switch is released this holds the motor on.
Perhaps it is just dirty.
If the mechanism is broken you need a new motor.
martyglo
#3 Posted : Wednesday, May 20, 2009 5:28:47 AM(UTC)
martyglo
thank you for your reply, would it help you if i faxed you a copy of the wiring diagram so we can figure this out without calling in a service person. thank you, marty
martyglo
#4 Posted : Wednesday, May 20, 2009 8:57:08 AM(UTC)
martyglo
thank you for your reply, can i fax you a copy of the wiring diagram so we can resolve this. thank you
#5 Posted : Friday, May 22, 2009 4:51:56 PM(UTC)
Do not have a fax
You could scan it and use the Insert Image to add it to a reply.
Sorry for not responding earlier but I have been out of town for a few days.
GE Dryer won't stay on (Dryer Repair)
by Guest 6/21/2024 2:16:20 PM(UTC)
Ge dryer will not stay on (Dryer Repair)
by Guest 5/10/2024 3:25:16 PM(UTC)
GE dryer timer issue (Dryer Repair)
by Guest 5/8/2024 11:47:16 AM(UTC)
GE Dryer Timer and Housing (Dryer Repair)
by Guest 3/25/2024 7:47:59 AM(UTC)
Humming/Rattle After Blower Wheel Replacement - GE Dryer (Dryer Repair)
by PISCDryer 11/8/2023 7:10:25 AM(UTC)
GE Dryer Not Heating - Model: GFDS140ED0WW (Dryer Repair)
by laflair13 3/1/2023 3:14:27 AM(UTC)
GFD55ESSN0WW GE Dryer stays on Pause when I press start (Dryer Repair)
by Guest 6/8/2022 6:54:15 AM(UTC)
No power or panel lights to GE Dryer (Dryer Repair)
by Guest 4/1/2022 4:03:52 PM(UTC)
No panel lights GE Dryer (Dryer Repair)
by Guest 4/1/2022 4:00:44 PM(UTC)
GE Dryer Model DWSR483EG9WW Squeaky & Loud (Dryer Repair)
by pdl2 12/23/2021 12:10:27 PM(UTC)
Gas GE dryer (Dryer Repair)
by Guest 6/20/2021 10:17:53 AM(UTC)
GE DRYER PART INTERCHANGEABLE (Dryer Repair)
by Guest 3/27/2021 12:02:09 PM(UTC)
GE dryer keeps pausing (Dryer Repair)
by ffltstn 3/23/2021 7:15:37 AM(UTC)
Will my GE Dryer still work (Dryer Repair)
by JW Appliance 1/29/2021 11:07:33 AM(UTC)
Trying to replace a GE dryer motor (Dryer Repair)
by Gigs34 9/8/2020 9:59:46 AM(UTC)
