The dryer operates great other than the rattling noise. It started about a month ago. It sounds like a wire bundle is hitting something or something is loose. I removed and cleaned out each of the fins with no change. I gained access to the rear of the dryer and didn't find anything loose. Any suggestions would be appreciated. Thanks.
Eric
