the dryer works but it makes a rattling sound when turned on.
Check that the fins inside the drum are tight. Couldbe something has fallen into the blower.
Try to narrow down where the rattle is coming from, the open the unit up to see if all movingparts are tight and not worn. |
THIS FORUM IS DEAD!!!!!!! |
