fordphantom40
#1 Posted : Thursday, June 18, 2015 12:53:10 AM(UTC)
fordphantom40
Okay I have this Maytag Atlantis dryer that I bought used about 2 year ago. Got it home and it worked like a charm. I had to move and after moving in the dryer started of working fine. then about a month later the dryer timer would not spin on perm press or regular dry but it spun on timed dry. Then about 3 weeks ago it would not start so I ordered a new timer for the dryer. The dryer model is MDE7400AYW and the serial # is 19728810cj. the new timer is 33002803. After installing the new timer it starts like normal but the timer still does not advance on Perm press or normal dry but it does advance on timed dry. is this the timer or is there something else that could be causing the problem.
#2 Posted : Thursday, June 18, 2015 2:59:26 AM(UTC)
Here are your parts, includes a wiring diagram.
Parts for Maytag MDE7400AYW Dryer - AppliancePartsPros.com
Here is a manual which should help.
You will have to join the site and be logged in to be able to download the manual.
http://appliancejunk.com...e&id=67;t=1434624457
Have you checked/cleaned the sensor bar (item 6 in section 07)?
The way it works is that when there is moisture between the two metal strips there is low current flow. The dryness board senses this and holds the timer advance off. When the clothes are dry, there is no moisture therefore no current path and the dryness board advances the timer to off.
So if the sensor bar is dirty the unit thinks the clothes are wet and does not advance.
fordphantom40
#3 Posted : Thursday, June 18, 2015 4:46:04 AM(UTC)
fordphantom40
Does the dampness sensor have one or two wires on it.
#4 Posted : Thursday, June 18, 2015 5:54:23 AM(UTC)
Should have two but I am not 100% sure about this.
fordphantom40
#5 Posted : Thursday, June 18, 2015 6:10:26 AM(UTC)
fordphantom40
Okay I took of the front of the dryer and found a blue wire laying inside and put it back on the damp sensor and that solved the problem. I want to thank you for all of your help. I really appreciate it.
#6 Posted : Friday, June 19, 2015 2:06:20 AM(UTC)
You are welcome.
And thanks for getting back to us. Now when others search for a similar problem they will see what actually worked instead of just suggestions about what could be the cause.
Knob Timer Problems (Washer Repair)
by RickTim 2/23/2011 9:44:32 AM(UTC)
Timer problems on Maytag Atlantis washer (Washer Repair)
by Zeffer 1/17/2011 8:57:58 AM(UTC)
timer problems (Washer Repair)
by eliot19 4/9/2010 9:14:45 AM(UTC)
Timer problems (Washer Repair)
by hitmehhh 4/9/2010 4:28:23 AM(UTC)
by strutta 10/8/2008 2:46:26 PM(UTC)
Dryer Timer Problems (Dryer Repair)
by Paulm77 2/6/2008 1:31:47 PM(UTC)
