Mybts
#1 Posted : Wednesday, May 6, 2015 3:47:29 PM(UTC)
Mybts
Have an upright kenmore freezer and it is not sealing. Its about 2 1/2 years old and it normally releases suction sound when the door is shut. At times it will not seal. Just the slightest touch will open the door. Ive checked the weight of items on the door and the seal is still in good shape. There are water droplets on the top and very fine ice crystals on the top. Not sure what to do. This is an on again off again issue.
#2 Posted : Thursday, May 7, 2015 1:55:19 AM(UTC)
A model number may be helpful.
On many units there are plastic cams on the lower door hinge. When closed the door is on the down side of the cam. This keeps the door closed.
Perhaps one or both of the cams is broken.
Also check the hinge side of the seal. Sometimes they can grab and twist when the door closes this can cause a poor seal. A light coating of white lithium grease or vaseline usually solves this problem.
#3 Posted : Thursday, May 7, 2015 1:57:04 AM(UTC)
Duplicate
Site or my computer is having problems this AM
#4 Posted : Thursday, May 7, 2015 2:04:49 AM(UTC)
Duplicate
Sphere478
#5 Posted : Thursday, May 7, 2015 6:56:07 PM(UTC)
Sphere478
The cams help but the magnetic strips in the gasket are what keep the door sealed on most models.
See if the door closes if you take everything out of the freezer invluding shelves. We get calls all the time for domething touching the door on the indide. It can be deceptively hard to figure out lol
Frigidaire upright freezer to warm (Refrigerator & Freezer Repair)
by jrklund311 1/11/2024 2:51:18 PM(UTC)
Frigidaire upright freezer temperature display acting strangely (Refrigerator & Freezer Repair)
by redroverguy 1/1/2024 11:34:30 AM(UTC)
Kenmore upright freezer cycle of warming up then chilling below zero. (Refrigerator & Freezer Repair)
by bigcheesehead 9/27/2023 9:05:10 AM(UTC)
Kenmore upright freezer model 253.280528015 keeps tripping ground fault (Refrigerator & Freezer Repair)
by Guest 8/24/2023 11:17:55 AM(UTC)
Frigidaire upright freezer model FFFH17F2QWA (Refrigerator & Freezer Repair)
by Guest 4/6/2023 11:29:17 AM(UTC)
Frigidaire Upright Freezer Misbehaving (Refrigerator & Freezer Repair)
by sun_lover 3/23/2023 12:32:46 PM(UTC)
Green Light at bottom front of Frigidaire upright freezer (Refrigerator & Freezer Repair)
by Guest 9/7/2022 10:43:50 PM(UTC)
Sears cold spot upright freezer Model #2423 (Refrigerator & Freezer Repair)
by Guest 9/1/2021 6:06:27 AM(UTC)
Whirlpool Upright freezer throwing itself into defrost mode (Refrigerator & Freezer Repair)
by Wayne O 7/26/2021 10:25:04 AM(UTC)
Frigidaire upright freezer runs for several hours then shuts off (Refrigerator & Freezer Repair)
by Guest 7/21/2021 11:32:11 AM(UTC)
Frigidaire Upright Freezer (FFH17F7H) showing wrong temperature (Refrigerator & Freezer Repair)
by Guest 7/21/2021 6:21:52 AM(UTC)
Frost/ice on only one upright freezer shelf (Refrigerator & Freezer Repair)
by whitedavidp1 4/28/2021 12:33:57 PM(UTC)
Defrost cycle-Fridgidaire mod FPUH19D7LF1 upright freezer (Dishwasher Repair)
by samv 6/23/2020 1:02:25 PM(UTC)
upright freezer frosting/icing after gasket replacement (Refrigerator & Freezer Repair)
by woakley 9/30/2019 7:09:57 AM(UTC)
GE 20DADRWH Upright Freezer (Refrigerator & Freezer Repair)
by Robo1027 3/3/2019 3:47:26 PM(UTC)
