luba
#1 Posted : Sunday, May 17, 2009 1:40:11 PM(UTC)
luba
dryer won't heat already replaced 2 coils and the ignitor still won't heat what do we do next
LoginFreak
#2 Posted : Sunday, May 17, 2009 1:44:37 PM(UTC)
LoginFreak
Have you checked the thermal fuse for continuity?
It's found at the back of the dryer on the vent housing.
And is white.
I would think that is the next thing to check.
And the most common one to replace as well.
If you go to this link: 11074932200
The first part on the list is the fuse. Check it out and let us know.
luba
#3 Posted : Tuesday, May 19, 2009 9:24:30 AM(UTC)
luba
turned on dryer used volt meter on both terminal and it showed power..
What's next
LoginFreak
#4 Posted : Tuesday, May 19, 2009 2:26:48 PM(UTC)
LoginFreak
What's next
Umm.. I didn't mention to check for power at the fuse.
I mentioned to check the fuse itself.
You have to check to see if the fuse is open.
Either with a continuity test or Resistance test.
Or by taping both wires together and turning it on to see if it works.
The wires going to the thermal fuse should be blue.
Take them both off and plug them together then tape them.
Then plug the dryer back in.
Then turn it on and see if it heats.
jillcgross
#5 Posted : Tuesday, May 19, 2009 2:49:31 PM(UTC)
jillcgross
Where is the fuse located on a GE profile serious. I replaced the motor and heating coil, but it still willl not heat up. any thoughts?
Todd
LoginFreak
#6 Posted : Tuesday, May 19, 2009 3:05:27 PM(UTC)
LoginFreak
Todd
It would be best for you to start a new thread.
Since the GE dryers are very different compared to the Kenmore by whirlpool.
I don't want anyone reading this thread and following the wrong directions.
Guest (4)
Samsung dryer wont heat (Dryer Repair)
by Dabenthall 12/19/2016 10:51:29 AM(UTC)
my whirpool duet dryer wont heat (Dryer Repair)
by bluelake78 12/18/2016 7:01:30 PM(UTC)
by bennieman 11/9/2016 10:30:17 AM(UTC)
by mkrason 12/18/2015 3:28:25 PM(UTC)
Maytag Dryer wont heat (Dryer Repair)
by Rescal 8/18/2015 5:23:15 PM(UTC)
by highcountry71 8/16/2015 8:42:56 AM(UTC)
Kenmore 80 Series...Dryer Wont Heat... Tested/continuity good (Dryer Repair)
by xtacbyme 6/3/2015 7:57:15 PM(UTC)
dryer wont heat in timed dry mode (Dryer Repair)
by thildy 5/7/2015 2:26:44 PM(UTC)
by Jim Winkels 4/5/2015 5:08:25 PM(UTC)
Whirlpool dryer wont heat (Dryer Repair)
by ekujustice 4/2/2015 4:47:16 PM(UTC)
Dryer wont heat on timed dry and works sometimes on auto setting (Dryer Repair)
by AJM57 3/14/2015 8:45:13 AM(UTC)
by Nmiles 11/24/2014 2:22:06 PM(UTC)
electric dryer wont heat (Dryer Repair)
by janietodd 9/24/2014 11:10:25 AM(UTC)
ge dryer wont heat (Dryer Repair)
by appliancerepairguy 9/13/2014 11:31:54 PM(UTC)
Dryer wont heat - element and fuses/limiters fine (Dryer Repair)
by watsonwabbit69 6/19/2014 10:41:14 AM(UTC)
