I'm looking for the schematic / wiring diagram for the following whirlpool fridge ED5VHEXTB01. By the way has anybody tried to replace the timer control board (ADC)to a mechanical less expensive timer? if so please advice, or else I'm gona try myself.
Please see the attachment for the tech sheet. |
THIS FORUM IS DEAD!!!!!!! |
Thx guys, let me explain what I found, this might help someone else, the fridge will cool just fine then it would stop cooling every time we disconnect power and reconnect it will work again, first thought came to mind its the EDC, also you could hit the whole control panel and the fridge will start... any way, it was the thermostat failing to close.
