britta923
#1 Posted : Wednesday, March 18, 2009 11:45:14 AM(UTC)
britta923
Where can I get a diagram of the interior of GE part #WD21X10169?
Thanks.
Drags1998
#2 Posted : Wednesday, March 18, 2009 11:55:20 AM(UTC)
Drags1998
Should be in the pack under the dishwasher, If its not there, please explain the problem your having,:) and we may be able to help.
britta923
#3 Posted : Wednesday, March 18, 2009 12:08:25 PM(UTC)
britta923
D/W had stopped mid-cycle twice over three day period ... keypad dead, too. Came back to life once for a while, but has stayed dead after second malfunction. First tried replacing interlock switch with new from AppliancePartPros ... no change in status. Just replaced with new (free) control module assembly from GE (under the wire before warranty expires) ... unit still dead. Wondering if I could have reversed the position of the two internal switches in the interlock switch assembly when I replaced it ... they look identical but have slightly different numbers on them ... and if that could be an issue. It still may be something else, but I don't know which way to go.
Thanks ... that's why I ask about a schematic.
Drags1998
#4 Posted : Wednesday, March 18, 2009 1:22:32 PM(UTC)
Drags1998
Wow, Thats a tough one, After looking at the parts manual, I really don't see anything else it could be??? Do you have a way to check for power at the board? I find it hard to believe that the door switch isn't just a plug in part. Carefully check the connection to the HOUSE wiring!!! Thats all I can think of!!!:)
