A helpful relative found the leak coming from the solenoid water valve, WR57X10026. He carefully marked the old valve, and the hoses, and then CUT THE HOSES ABOVE THE MARKINGS! I need a schematic of the hose connections so we can install the replacement part with the right connections. A physical picture of the valve showing which hose goes from which port to what would really be a big help! Thanx! --doug
Here is the part. If you click on the picture a new page will open with a Q&A section that has info on how to hook it up. Part number: AP2071738
THIS FORUM IS DEAD!!!!!!! |
