Lovemydog
#1 Posted: : Tuesday, April 28, 2015 6:40:21 AM(UTC)
Lovemydog
My Kenmore Elite He4 dryer will not spin. When I hold the door switch down and press start it hums and I get heat, the fan turns on and I feel air coming from the back. If I spin the drum it turns but then stops.
Any advice or suggestions are greatly appreciated. Thanks
fairbank56
#2 Posted : Tuesday, April 28, 2015 8:03:48 AM(UTC)
fairbank56
Groups: Expert
Odd symptoms. I would say a broken belt but this model has a broken belt switch so the motor would not run if the belt was broken. If you have air flow, then the motor is running. Maybe the belt is worn/stretched and slipping or the idler pulley is wearing out.
Eric
Lovemydog
#3 Posted : Tuesday, April 28, 2015 11:04:31 AM(UTC)
Lovemydog
Thank you. Fairbank56. I'll carefully try to take it apart and look at the belt.
Lovemydog
#4 Posted : Thursday, April 30, 2015 12:29:13 PM(UTC)
Lovemydog
Ok. I replaced the pulley and the belt. Now that it's back together when I hold the switch on with the door open I hear a hum and when I spin the drum it continues to spin. So now it is that it won't start to spin.
Any suggestions would be grateful.
Lovemydog
#5 Posted : Thursday, April 30, 2015 12:47:40 PM(UTC)
Lovemydog
Yes it's me again. If I put clothes in it and then spin it, it starts to squeal and stops. So is it the motor?
fairbank56
#6 Posted : Thursday, April 30, 2015 2:33:54 PM(UTC)
fairbank56
Groups: Expert
Well, I can't troubleshoot your dryer from here so I can't say for sure if it's the motor. It could be one of the drum rollers is binding and preventing the drum from rotating.
Eric
Lovemydog
#7 Posted : Thursday, April 30, 2015 5:24:34 PM(UTC)
Lovemydog
Thanks for the advice. One of the rollers was not
as smooth as the others but I did not realize that
it would keep the drum from turning. Thanks again
Samsung dryer won't spin (Dryer Repair)
by Guest 8/13/2023 2:50:03 PM(UTC)
DV448AEP/XAA Dryer Won't Spin (Dryer Repair)
by hufe1983 1/13/2020 4:48:55 PM(UTC)
After repair, dryer won't spin with clothes (Dryer Repair)
by skyledavis 8/9/2016 6:39:35 PM(UTC)
GE dryer won't spin....except sometimes! (Dryer Repair)
by Cbee78704 11/29/2014 4:13:53 PM(UTC)
Kenmore Dryer won't spin (Dryer Repair)
by Connito 7/29/2014 5:59:09 AM(UTC)
Dryer won't spin fast (Dryer Repair)
by ezfreeze 8/2/2013 9:30:03 PM(UTC)
HELP! Dryer won't spin (Dryer Repair)
by askmelater 10/31/2012 12:43:09 PM(UTC)
Whirlpool Dryer won't spin (Dryer Repair)
by jumbo_rider 4/26/2011 6:24:22 PM(UTC)
Kenmore 98702 Stacked Washer/Dryer won't spin (Washer Repair)
by flashpipe 4/21/2011 5:31:40 AM(UTC)
by mtbikechick1 2/9/2010 3:28:08 PM(UTC)
Dryer Won't spin unless pushed by me (Dryer Repair)
by Rebillbula 4/4/2009 10:38:22 AM(UTC)
by jesco76 4/2/2009 5:45:44 PM(UTC)
by Lingot 1/5/2009 7:19:10 PM(UTC)
by Peter H 11/11/2008 7:56:09 AM(UTC)
by LostinMS 8/17/2008 3:49:16 PM(UTC)
