Originally Posted by: Shmota ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Yes, I did. If you are still having problems let me know and I will leave a link to help. Can you please send me the solution to the leaking water into the freezer? Thank you
I see that other have had the same problem. What was the solution???
Thanks, Darryl
Yes. The drain has ice in it. At the back of the fridge section there is a center bump and two downward sloping "ramps" on each side of the center bump. Either defrost completely, or pour hot water on the "ramps." I took mine completely apart and changed the defrost Tstat, which is what I think causes the problem in the first place.
Later, and stay safe. Bill
Could you post the link you used to repair?
Originally Posted by: deepwilliams ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) I'm having the same problem and can't find the solution. Can someone help?
Thanks! I am having the same problem. Can some help?
freezer iceing to lower freezer
Originally Posted by: Shmota ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Yes, I did. If you are still having problems let me know and I will leave a link to help. I am having this problem - lots of ice in the bottom of the freezer part. What is the solution and can you help - Thanks KJF17
Rank: Guest
Joined: 8/10/2018(UTC) Posts: 0 ![United States United States](/Content/images/flags/US.png) Location: 99556 Was thanked: 4 time(s) in 4 post(s)
I’m having the same problem as well…can someone please post the solution? Is there a link?
