I have a Gladiator garage freezerator. Top section is refrigerator lower secion Freezer. A month ago I started finding small ice deposits on the top shelf of the freezer. It is now getting worse, more and more water leaking from the opening in between the secions, square hole top center of loer compartment by vent. lots of water now forming to ice. Thanks in advance for the help. Thomas
Originally Posted by: Shmota  I have a Gladiator garage freezerator. Top section is refrigerator lower secion Freezer. A month ago I started finding small ice deposits on the top shelf of the freezer. It is now getting worse, more and more water leaking from the opening in between the secions, square hole top center of loer compartment by vent. lots of water now forming to ice. Thanks in advance for the help. Thomas Shmota, I am having exactly the same leak with my Gladiator, did you ever get an answer? -- gary
Yes, I did. If you are still having problems let me know and I will leave a link to help.
Originally Posted by: Shmota  Yes, I did. If you are still having problems let me know and I will leave a link to help. Please do, still have the problem and would love to have your link for help. thanks, -- gary
Originally Posted by: castlecreep  Please do, still have the problem and would love to have your link for help. thanks, -- gary I am also having this problem. Can someone post the solution? Thanks. Eric
I have a Whirlpool Gladiator Freezerator that is building ice on the bottom part. Need to knife it out about every other month. What is the solution? Very frustrating. I don't understand how this can happen. Thanks for any help :) .
I am also having the same problem. Could someone send me the solution also? Thank you!
Originally Posted by: Shmota  Yes, I did. If you are still having problems let me know and I will leave a link to help. Can you please let me know the solution. I have had 2 service call by authorized repair companies and my refrigerator is still leading into the freezer. Thank you.
Originally Posted by: Smith1234h  I'm having the same problem and can't find the solution. Can someone help? Thanks!
