2 Pages<12
mb52
#11 Posted : Saturday, August 4, 2012 9:22:44 AM(UTC)
mb52
Originally Posted by: Shmota Go to Quoted Post
Yes, I did. If you are still having problems let me know and I will leave a link to help.
Can you please send me the solution to the leaking water into the freezer?
Thank you
deepwilliams
#12 Posted : Sunday, August 5, 2012 8:16:43 AM(UTC)
deepwilliams
I see that other have had the same problem. What was the solution???
Thanks,
Darryl
NVCowboy
#13 Posted : Wednesday, November 6, 2013 8:13:16 PM(UTC)
NVCowboy
Yes. The drain has ice in it. At the back of the fridge section there is a center bump and two downward sloping "ramps" on each side of the center bump. Either defrost completely, or pour hot water on the "ramps." I took mine completely apart and changed the defrost Tstat, which is what I think causes the problem in the first place.
Later, and stay safe.
Bill
Clutch2014
#14 Posted : Tuesday, March 18, 2014 8:52:45 AM(UTC)
Clutch2014
Could you post the link you used to repair?
mlburke11
#15 Posted : Sunday, August 10, 2014 12:48:53 PM(UTC)
mlburke11
Originally Posted by: deepwilliams Go to Quoted Post
I'm having the same problem and can't find the solution. Can someone help?
Thanks!
I am having the same problem. Can some help?
sespecreek
#16 Posted : Monday, April 6, 2015 1:57:08 PM(UTC)
sespecreek
freezer iceing to lower freezer
KJF17
#17 Posted : Friday, May 1, 2015 1:13:45 PM(UTC)
KJF17
I am having this problem - lots of ice in the bottom of the freezer part. What is the solution and can you help - Thanks KJF17
KJF17
#18 Posted : Friday, May 1, 2015 1:15:20 PM(UTC)
KJF17
Guest
#19 Posted : Tuesday, December 7, 2021 9:42:53 PM(UTC)
Guest
Rank: Guest
Groups:
United States
I’m having the same problem as well…can someone please post the solution? Is there a link?
Guest (4)
2 Pages<12
