Temosupholstery
#1 Posted : 10 years ago
Temosupholstery
My dryer doesn't have flame. I changed the Igniter and checked the flame sensor. Sensor is fine. I also got a new Thermal fuse and new coils but still no flame. What can I do.
fairbank56
#2 Posted : 10 years ago
fairbank56
Groups: Expert
No glow from the ignitor? If not, your not getting power to it. You need to check to see where your losing power. Devices in that circuit are timer, temp switch, hi limit thermostat, thermal cutoff, operating thermostat, thermal fuse, flame sensor and motor switch. You can check voltage at each device to determine where your losing it or you can check continuity of each device. The motor switch would have to be activated manually.
Eric
Temosupholstery
#3 Posted : 10 years ago
Temosupholstery
Wich is the motor switch to be activated manually, and how you activate it, because everything tested good. I just don't get it.
fairbank56
#4 Posted : 10 years ago
fairbank56
Groups: Expert
So your getting 120vac to ground at either terminal of the flame sensor? If yes, and no glow from the ignitor, the ignitor could be bad or your not getting neutral to the ignitor via the motor switch. The motor switch is part of the motor. It is activated by a centrifugal mechanism inside the motor which operates a disc and lever to operate the switch. The two outer terminals of the motor connector (red wires) connect to the internal switch. You would need to check continuity across those terminals on the motor (wiring harness unplugged) while manually activating the switch with a screwdriver pushing against the disc within the motor frame.
Eric
UserPostedImage
Temosupholstery
#5 Posted : 10 years ago
Temosupholstery
Please help!!!! My dryer has no flame. I already did everything I could and nothing work. Tested everything and nothing. I was told that if I changed the Thermal fuse it is suggested to change the hi-limit thermostat even though it tests good. Could that be posible. Thank you in advance for all the suggestions.
Maytag Atlantis gas dryer model MDG7400AWW (Dryer Repair)
by Guest 8 months ago
Speed Queen gas dryer Model SDG809WF (Dryer Repair)
Samsung Gas Dryer no power (Dryer Repair)
by glenn55 8 months ago
MGD6000BWW Maytag gas dryer (Dryer Repair)
1998 Maytag Gas Dryer Drum Issue Has Me Stumped (Dryer Repair)
by semaas 9 months ago
Whirlpool gas dryer model WGD8300SW2 (Dryer Repair)
by Guest 9 months ago
Kenmore Gas Dryer Running Hot (Dryer Repair)
by Guest 10 months ago
Frigidaire gas dryer runs but no heat (Dryer Repair)
Kenmore gas dryer model 110.96742701 (Dryer Repair)
by Guest 12 months ago
Maytag MDG8400AWW gas dryer not drying clothes (Dryer Repair)
by tvr4 about a year ago
Samsung Gas Dryer - Model DVG50M7450* (Dishwasher Repair)
by Carl B about a year ago
Alternate T-stat for Speed Queen gas dryer (Dryer Repair)
by Guest about a year ago
Maytag gas dryer problem with model MDG5500AWW (Dryer Repair)
by Guest 2 years ago
Drum repair of old Speed Queen gas dryer (Dryer Repair)
DLGX8001W gas dryer clicks on control board but wont start (Dryer Repair)
