4 Pages<1234>
kawfeeman
#11 Posted : Sunday, December 16, 2007 8:26:50 PM(UTC)
kawfeeman
start at the valve (you should be able to see orifice, for the bake for reference , it is brass.. ) follow the tube from the valve up to broil burner ....
kawfeeman
#12 Posted : Sunday, December 16, 2007 8:30:12 PM(UTC)
kawfeeman
you should be able to see tube that comes from the valve... no ?
Page
#13 Posted : Sunday, December 16, 2007 8:38:49 PM(UTC)
Page
OK found it, looks pretty cruddy. Can't see hole without removing it, looks like it unscrews if I can get a wrench on it.
kawfeeman
#14 Posted : Sunday, December 16, 2007 8:40:18 PM(UTC)
kawfeeman
gentle gentle gentle...
Page
#15 Posted : Sunday, December 16, 2007 8:43:01 PM(UTC)
Page
Go it off and it is dirty but open. Will soak it in some cleaner, BOO Giants lost.
kawfeeman
#16 Posted : Sunday, December 16, 2007 8:46:01 PM(UTC)
kawfeeman
certain it is open ? ( thought for sure that it was a clogged orifice... )
Page
#17 Posted : Sunday, December 16, 2007 8:51:08 PM(UTC)
Page
See light through it.
Page
#18 Posted : Sunday, December 16, 2007 8:55:42 PM(UTC)
Page
A quick soak in oven cleaner and it looks like new.
kawfeeman
#19 Posted : Sunday, December 16, 2007 8:57:05 PM(UTC)
kawfeeman
and tube from orifice to valve has no little shutoff type valves that could be off ? ( when you replaced the broil ignitor, you made certain that the wires are not pinched ... ceramic wire nuts used ? and they are tight ?
Page
#20 Posted : Sunday, December 16, 2007 9:13:40 PM(UTC)
Page
Ignitor is getting hot, wire leads came with spade connectors, OEM replacement. No independent valve for broil line.
Orifice back on and clean. Started broil and slight smell of gas at orifice. Reconnected to oven and can get gas to light at broiler with match. Small amount of gas just burns off and goes out.
Guest (14)
no power to upper oven broiler ignitor (Oven Repair (including Ranges and Cooktops))
by Bill Patterson 2/9/2021 9:24:54 AM(UTC)
replaced broiler ignitor but still doesn't work well (Oven Repair (including Ranges and Cooktops))
by b*murphy 3/16/2015 1:00:58 PM(UTC)
Broiler ignitor (Oven Repair (including Ranges and Cooktops))
by greg@57 10/8/2012 1:02:44 PM(UTC)
Amana Broiler Ignitor Replacement (Oven Repair (including Ranges and Cooktops))
by HAWKE1023 1/2/2011 8:09:59 AM(UTC)
oven broiler ignitors (Oven Repair (including Ranges and Cooktops))
by Sammy D - Chicago 11/17/2010 7:33:07 AM(UTC)
Viking broiler ignitor problem (Oven Repair (including Ranges and Cooktops))
by skidgllfs 3/20/2009 5:36:40 AM(UTC)
oven/broiler ignitors (Oven Repair (including Ranges and Cooktops))
by glkearns 10/26/2008 1:47:51 PM(UTC)
Broiler Ignitor 4342528 (Oven Repair (including Ranges and Cooktops))
by Dennis49 5/9/2008 7:34:01 PM(UTC)
4 Pages<1234>
