josh39026
#1 Posted : Monday, March 23, 2015 6:25:06 PM(UTC)
josh39026
idk how old this freezer is as I got it from a friend as it just quit working and I figured I can try and fix it if not then to the dump it goes, as I am a big time DIY and I hate taking things to ppl, but i am a noobie at appliance so i been reading online as much as i can but i havnt found much of an answer other than general basic stuff so i need help in trying to figure out if my motor is bad which im thinking its not because i don't hear a clicking in the back which brings me to why im thinking its my starter relay but im having trouble trying to understand how to test it with a multimeter as the multimeter that i have doesn't have a continuity tester on it however im gonna be getting one so i just need help in trying to figure out how to test the starter relay and the overload....which i don't know if that would affect the freezer from starting.
when the freezer is plugged in i see that the little power light is on but other than that nothing...it doesn't get cold nor do i hear any clicking or trying to start.
any help and input is much appreciated again im still learning all this and how to use a multimeter
#2 Posted : Tuesday, March 24, 2015 2:22:03 AM(UTC)
A model number may help others help you.
Find your model number - AppliancePartsPros.com
Also is it a chest freezer or an upright unit.
The first thing to check would be the control thermostat.
It's contacts should be closed.
Below is my usual blurb on meter usage which may be helpful to you.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
Another way to check the thermostat is to unplug the unit and the two wires that go to the thermostat's contacts. Then short those wires together, making sure that they cannot short to anything else. Then plug the unit in to see if the compressor starts up.
Also note that there are two types of compressor start devices.
One is a standard relay, the other is a solid state device. The solid state unit cannot be checked easily so usually it is a replace to check it, if the compressor windings check out OK.
Also there is an over heat (clixon) on most compressors.
Below is a good link with general repair info.
How To Fix a Refrigerator - Appliance Repair Guide - ACME HOW TO.com
josh39026
#3 Posted : Monday, April 13, 2015 5:59:55 PM(UTC)
josh39026
I don't know the model number as there is non on the chest deep freezer whoever had it before my friend who gave it to me had painted over it or it was torn off or feel off but I LOOKED EVERYWHERE and even looked on the internet for possibilities of where it could be, but nothing.
ive read the stickys as well.
ive reviewed the links multiple of times I believe I am getting a closed circuit from the compressor relay, I havnt been able to check the compressor itself as I am unsure but I am gonna do more research into checking the compressor properly. and when you say checking continuity you mean checking as well if it is a open circuit vs closed circuit?
I don't know how to short the wire to check the thermostate if you can elaborate more on it that would be great as well as I will research some more on the internet.
I believe I might have a solid state compressor relay
#4 Posted : Wednesday, April 15, 2015 1:15:11 AM(UTC)
[COLOR="Blue"] when you say checking continuity you mean checking as well if it is a open circuit vs closed circuit[/COLOR]?
Yes.
Also checking if a compressor winding is ground out ( shorted to the case).
See the link I included.
The thermostat should have two wires going to it.
If the ends plain connectors just pull them off the thermostat and tape them together (short them). Make sure that they cannot short to anything else. Then plug the unit in and see if the compressor starts.
If the connectors are covered is plastic then you could use a paper clip to short the two thermostat connectors together.
Just make sure that the unit is unplugged when working on it.
