A model number may help others help you.
Find your model number - AppliancePartsPros.comAlso is it a chest freezer or an upright unit.
The first thing to check would be the control thermostat.
It's contacts should be closed.
Below is my usual blurb on meter usage which may be helpful to you.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
Another way to check the thermostat is to unplug the unit and the two wires that go to the thermostat's contacts. Then short those wires together, making sure that they cannot short to anything else. Then plug the unit in to see if the compressor starts up.
Also note that there are two types of compressor start devices.
One is a standard relay, the other is a solid state device. The solid state unit cannot be checked easily so usually it is a replace to check it, if the compressor windings check out OK.
Also there is an over heat (clixon) on most compressors.
Below is a good link with general repair info.
How To Fix a Refrigerator - Appliance Repair Guide - ACME HOW TO.com
