cubbiesbp
#1 Posted : Wednesday, March 11, 2015 1:02:55 PM(UTC)
cubbiesbp
Hi...when I hit the start on my dryer, it sounds like it goes to start, but then does not. I open the door real quick and can see that it turned over, but did not "catch" and start running. I will try this again and it seems like it is about to start, there is a noise like it is starting, but it does not seem to "catch" and run normally. Once in a while, it does "catch" and runs for about 30 minutes and stops by itself..then I cant start it again.
Then, the button just clicks and nothing happens after I have tried to start it a few times.
Are we looking at a thermostat issue?
fairbank56
#2 Posted : Wednesday, March 11, 2015 5:54:08 PM(UTC)
fairbank56
Groups: Expert
This is not a thermostat problem. If you hold the start button, will it stay running? Then quits when you release the button? If so, looks like a bad motor.
Eric
cubbiesbp
#3 Posted : Thursday, March 12, 2015 6:07:57 AM(UTC)
cubbiesbp
Thx FB
When I press the start, it sounds like it wants to start but won't. Kind of like when a car turns over but never catches. Then, the start button just clicks and I can't even get that turnover action.
The motor is probably a good call
Amana electric dryer not working (Dryer Repair)
by Guest 5/3/2024 10:43:01 AM(UTC)
Kenmore Elite Electric Dryer not working (Dryer Repair)
by Guest 7/24/2022 7:10:35 AM(UTC)
GE Dryer Not Working (Dryer Repair)
by DWMarsh 4/14/2020 2:43:03 PM(UTC)
Gas dryer not working properly after power outage (Dryer Repair)
by Frazierfam5 3/7/2016 4:43:32 PM(UTC)
by Cynthia Sosa 9/25/2015 7:00:01 AM(UTC)
Maytag Bravos Electric dryer not working after Power failure (Dryer Repair)
by JohannesB 6/29/2015 3:16:19 AM(UTC)
dryer not working on timed cycle (Dryer Repair)
by kwikk4 2/23/2015 7:53:40 AM(UTC)
Dryer not working properly (Dryer Repair)
by gdmcc1955 8/5/2014 9:59:33 AM(UTC)
by Vitocar 6/17/2014 11:12:39 AM(UTC)
dryer not working (surprise!) (Dryer Repair)
by thebrokenwhirlpool 3/8/2014 11:26:54 AM(UTC)
Dryer not working right (Dryer Repair)
by Monsters 10/1/2013 6:59:17 PM(UTC)
Kenmore dryer not working (Dryer Repair)
by JuanY 5/21/2013 8:57:38 AM(UTC)
Roper dryer not working in auto sense mode. (Dryer Repair)
by CWeasel 7/15/2012 10:03:37 AM(UTC)
by redrider65 2/20/2012 1:25:39 PM(UTC)
Kenmore Gas Dryer Not Working (Dryer Repair)
Belarus silverevo05 2/13/2012 9:08:27 AM(UTC)
